mopowers
Does anyone make -6AN black nylon braided PTFE hose???
I'll be using it to plumb my transmission cooler. I'll have to look into the Proclassic line. Thanks!
summit says this will work. Good to 275degrees and 350psi. The only warning they give is to use a ptfe if using this line for fuel and you are unsure of what additives it may contain. I am going to try this hose for my cooler lines on my sweptline.
http://www.summitracing.com/int/parts/sum-240620b/applications
