gtokid1 Well-Known Member Joined Mar 6, 2016 Messages 91 Reaction score 48 Location michigan Jun 20, 2019 #1 Have a 1964 B Body that the brake booster Midland Ross check valve might be bad. How do you test and were are the replacements found. Thanks
halifaxhops It's going to get stupid around here! FABO Gold Member Joined Jan 20, 2014 Messages 87,025 Reaction score 67,317 Location Hoppyworld, PA Jun 20, 2019 #2 Easy check run the engine so it fills with vacuum, shut down pull the hose off if bad you will hear the vacuum sucking through the hose. If good pull the valve from the booster and you will hear it sucking through, nothing if bad
