[FOR SALE] Brake Booster Off Of 1974 Duster ($20)
dICKj
Kilgore, TX
Rating - 0%
0   0   0
The brake booster in the photo is for sale to the best offer plus shipping. The master cylinder has been removed and is not included. The brake pushrod that goes to the pedal is not included, I used it to make a conversion. I hate to see this brand-new booster go to waste on the shelf in my garage. I paid a local "expert" a bunch of money to make my brakes right. They turned out to be good enough to get it off the trailer. The push rod was about an inch to short, so I would push on the pedal forever and then lock 'em up! I gave up and changed it over to manual brakes. The booster was ordered from Summit because I saw the box, but there is not a single number anywhere on it. Make me any reasonable offer over $20 plus shipping and it's yours. DickJ
I'm about to dump my 74 Duster PB and go manual also.
Got the adjustable pushrod and rubber piece . What Master did You go with?
I used the same master cylinder right off the P/B system. I made my own adjustable rod with part of the old one cut off and threaded, a double end coupler nut, two lock nuts, and a grade 8 bolt cut off and rounded on the end. It works great!
DJ
