Brake id
DartGT55
USA
Can anyone tell what dis brakes and pads these are for thanks
Looks like the first picture has a number that's from the caliper bracket on a '73+ disk set up, the 10.95" version. Second picture looks like a 73+ single piston caliper.
The reason I ask because they are on a 68 dart just trying to see if they were what came on it
that most certainly would not have come on anything pre 72. those would've come off anything from 73+ and a lot of the components are shared across several body styles thru the 80's
a quick note: with the calipers mounted to the front there is a possibility of the caliper contacting the swaybar bits at full lock.
if the front is big bolt, chances are the rear is as well but never trust-- always verify!
The rear are drums
Just trying to make sure they are safe and again thank you
