7dart0
mine is just hanging not mounted courtesy of previous owner. does anyone have a picture of how it is installed?
thanks tom
thanks tom
I found this thread searching for an answer to my problem...and now I'm only more confused. Recently, I realized my brake lights were stuck on, and I thought my switch had gone out. I ducked under the dash to investigate and found the switch mounted there, in the bracket, everything tight, but it's not touching the pedal! I mean, it's not even coming close! How it EVER worked where it is is a complete mystery. The bracket doesn't look bent, and the switch looks to be installed correctly. Is there something that maybe goes BETWEEN the switch and the pedal, that might have fallen off? I can't really tell in the pic.
Thanks!
Mike
Mike,
Is your brake switch as far forward as the slot allows? If so, it sounds like either you have the wrong PN installed or your brake pedal is not coming back far enough (how does it align with the accelerator pedal?). If the later, investigate your master cylinder and mounting. Perhaps you have a power MC & rod in a manual brakes car, or maybe a later 2 - hole MC with an adapter plate which moves it out farther. I assume somebody unplugged the switch, otherwise your brakes lights would always be on.
Here is a pic of the threaded style
