dan5354
I am wondering whether I need to replace my brake lines. The car was sitting for 15 years and seldom used. The front brake reservoir was dry when I checked it, the rear was full but the fluid was very dirty. I have decided to get rebuilt calipers and replace the rear wheel cylinders as well as the master cylinder, since they are rather inexpensive. My question is - do I need to replace the lines or can they be just flushed out and put in a synthetic fluid to help keep out moisture. The outside of the lines look to be in good shape, but there was a bunch of rust in the bottom of the master. The fittings up front are rusted and I can't get them loose even with a tubing wrench, but they could be cut and re-flared. Thanks
