soaringcowman
- Joined
- Jul 9, 2007
- Messages
- 151
- Reaction score
- 0
Ok so i've been doing a /6 to v8 swap, 10" brakes front and rear, i need to replace my brake lines and am going to buy them from inlinetube. now my question is i plan on upgrading to disc brakes front and most likely rear, will i have to redo everything i'm replacing now? or will it all be the same for disc, i know the master cylinder has to be swapped but didn't know if i had to change any of the hard lines or the distribution block? And on the topic of the distribution block how do you know if you need to replace these or not? Didn't know if they went bad at all?
thanks
adam
thanks
adam
