Brake Pedal Assembly (arm)
TF360
Florida
74 Duster- Is the Brake Pedal Arm any different on a Power Brake car vs a Manuel Brake car, or is the Pedal assembly the same and only the Brake Rod different? Thanks for any help
The pedal assembly is the same. The push rod for manual brakes goes straight from the pedal into the rear of the master cylinder. The power push rod is part of a bell crank assembly that offsets up on the firewall to give you more clearance around the driver's side valve cover. The final link going into the booster and the pushrod from the booster to the master cylinder are different rods than what the manual cylinder uses.
Thanks a lot Cudamark. I was wondering because on some cars the Pedal Arm is different on a Manuel Brake car. So, only the push rod is different-on ours. Going from power to Manuel, and I already have a adjustable push rod.
