Brake pedal Bracket Question?
frederick_76
Milton, Wa.
Will the 4 speed brake and clutch pedals fit in the stock bracket from my automatic, or do I need a bracket from a manual trans??:?:
Just compared the sets I have. The brackets are the same. The only one to watch for is the heavy duty set. They have needle bearings in the clutch pedal shaft and have a different size hole going through the housing.
