my68barracuda
And Dr Diff said the same thing, the smaller MC piston will increase travel but also increase pressure.That's what she said.
So what about increasing free pedal height?
Do you have an adjustable M/C pushrod?And Dr Diff said the same thing, the smaller MC piston will increase travel but also increase pressure.
I do not, IIRC I reused the stock mc brake pushrod.Do you have an adjustable M/C pushrod?
Because in your original post you said "The car stops OK, certainly nothing outstanding". My point was that I have the same set up and my pedal is rock hard and will lock all tires if necessary. Then I read that you have TWO brake pressure gauges? You're on a different level than me brother, sorry I muddied up your thread.and I am not sure where the soft pedal comments are coming from, I never said that. The pedal resistance is fine. I my question has to do with free pedal height.
Thanks
info on the TWO brake pressure gaugesBecause in your original post you said "The car stops OK, certainly nothing outstanding". My point was that I have the same set up and my pedal is rock hard and will lock all tires if necessary. Then I read that you have TWO brake pressure gauges? You're on a different level than me brother, sorry I muddied up your thread.
I have brake pressure gauges mounted in the car that show pressure right at the MC for the front and rear brake system. They both pick up immediately and show pressure on the gauges upon moving the pedal, and the pedal movement does not seem excessive, at full leg strength push I am no where near bottoming out the pedal.
A direct copy from the first post is: So is a brake pedal travel of 2 to 3 inches sound right, was not saying that the brake had to be depressed that far to get the brakes to apply. The 2 to 3 inches was total travel,
Post #2 shows about an inch and a half of travel, that guy said Pressed hard but not two foot hard. So that is probably in line with what I have
I probably have stronger than average arms, I was close to full brake pressures, had 650 PSI on the gauges with my arm pressure when I took my measurements. I can get 850 psi when I jamb on it with my leg.
Let me re phrase the question,
would going to an adjustable brake rod allow me to set the height of the brake pedal higher?
