Brake pedal shaft
cudamike13
cudamike13
Mineral Bluff Ga
Hi all. I'm in process of getting my 67 ready to accept motor and trans. I have "finished" brakes, but I have a question.
At end of rod that attaches to brakes pedal lever, the hole is very large. So large that unless I firmly tighten nut, it moves around. If I tighten nut so that doesn't happen, then rod is bound to lever and it needs to move.
Any help with this is greatly appreciated!!
67 Barracuda.
Are you using the correct shoulder bolt?
