Brake question
tekslk
McClure, Pa
Just installed power drum brakes on my 67 cuda, They work great driving car, but not so good at idle, pulling car in and out of garage etc. Would a brake canister help this or is it something Imust live with.
a brake cannister will help. Your engine probably doesn't have too much vacuum at idle.
I figured its worth a try, where does everyone have theres mounted?
For a reservoir to be of any help it would need to be HUGE.
Lots of cam grinds wont produce enough vacuum to operate a brake booster at any rpm.
A better alternative to a cannister would be Rhoades lifters. They bleed down at idle and take out about 15° of duration and .025" of lift at idle. Then "pump up" by 3500 giving you the full lift and duration of your cam. You don't have to change the cam, just throw in the rhoades lifters. They will give you more vacuum at idle, smoother idle, better fuel economy, and bettter performance. They really work, I've been using them for 25 years now and had them in engines that ran over 200,000 miles. You can get a set through Summit Racing for $110.
http://www.rhoadslifters.com/
http://www.rhoadslifters.com/Pages/PartNumber.html
Here's an article about them:
http://www.rhoadslifters.com/Pages/Articles.html
Seriously, try the Rhoades lifters. It took me three years to be convinced, since then, I've run nothing but - even if the cam comes with new lifters, I use Rhoades.
In my 340 S with a .484/284 MP cam, it would idle choppy at 1100 rpm. After installing Rhoades lifters, I now idle at 800 more smoothly than the old lifters at 1100 rpm.
Give them a try, Rhoades only, not the knock offs. I've been using them for over 20 years now.
