helliphinon8
Before I weld these up, is there supposed to be holes or vents in the circled areas? I noticed the naval jelly penetrated all the way thru the cover as I was cleaning it up. Thx!
Thanks!Need venting above the gasket or it will create a vacuum on the reservoir side as the fluid level changes.
