Brake rotor question
barracudadave67
Burlington, Wi.
Hi All. Need some knowledge, and advice on brake rotors. Are 10.87 rotors the same as 11 in rotors,??. Will 11 in work on that set up. I was told i need 10.87 rotors. A member here has a set of 11 in rotors for sale, and I'd like to purchase them from him, if they will work with my spindles. I am in the process of rounding up parts to do a big bolt pattern swap on my project 66 Dart. I have spindles from an FMJ model.
barracudadave67
I'm guessing he's referring to the standard Cordoba 10.87 rotors which everybody calls 11" rotors. You should PM him and verify what the rotors are off of. I have the large rotors on my 75 Dart which uses the same spindle as the FMJ line. Dan
There from a 73 duster
You should be good to go. He must have changed them over at some time as the 1973-1976 had 10" rotors but used the Cordoba type spindle. You know you can buy all those parts new across the counter at your parts store. You'll need the caliper brackets if you don't have them or Mancini sells them amoung others.
