Yep, one thing about brakes is that you need to have everything perfectly clean and above all "new" when you do the brakes. That means no used shoes, which have been glazed by use and will not clean up no matter what you do. Also, when you turn the drums, they are mounted on the lathe by the bearing races, so they should turn true to the bearings, and thus the spindle. Of course, they could be off when mounted and probably are a little, as nothing done off the car will ever be perfect ewhen reinstalled, but they should be close. I vote for new shoes, and a fresh turn on the drums again to match the new shoes. Make sure you adjust them too, that'll go a long way to correct operation. And, with drums, they need to be re-adjusted often to keep them working at their peak!!! Good luck, Geof
