Markuscurillious
**** it I’m selling it
Are the front calipers mounted with the bleeder up ? At the highest point ?
Then is the proportioning valve tripped , try center it , open the front and rear bleeder to center it you should feel a click in the pedal if it Centers
- This how the 71/72 Or so down was done. They did not use the Newer combo valve. The older used a distribution safety valve and separate hold off/ “Texas”-proportioning valve.
Photos man photos. What is so hard to get photos from people.
"Doctor I have a bump on my face what is it?" How the heck can the doctor diagnose the problem from just that description
If you really don't have a proportioning valve no amount of adjusting or bleeding will fix it.
