iw378
I'm rewiring my car with an aftermarket "kit". Anyways I have the car running now with their ignition wiring. I had to fab a jumper wire from ign 1 to ign 2 on the back of the switch because their kit only has a 4 wire connection at the switch. I am working on the brake warn light now off of the factory schematics and am a little stumped. I'll start at the e brake switch.
I have a wire running from the ebrake switch to the correct pin on the cluster then that wire goes out to the switch on the proportioning valve. The other wire goes from the other brake warn pin on the cluster and going to ign 1 on the back of the ignition switch. Couldn't I just hook that wire up to a 12 volts with key on power ??
Any help appreciated.
Luke
Luke
