brakes again
Red Beard
Active Member
Cincinnati, Ohio
I have the uca's and spindles for my disk setup now, but all the rotors I can find are 5 x 4.5 bc and I want to keep the small bolt pattern. Anyone know anywhere to find them. All the parts houses have is LBP also. I thought all a-bodies had 5 x 4 thru '76.
thanks in advance,
James
They changed the bolt pattern in 73. The disk brakes before then with the 5 on 4 pattern used a different rotor setup. It is available, but a little more pricey. Not sure where you can get them though.
Also, I think the spindles are different for the 5 on 4 pattern.
Jack
Well I guess I'm buying new wheels for the front. My 8 3/4 has the small bolt pattern and I was hoping to keep them all the same. Back to the parts store I guess...
Thanks Jack !!
James
