brakes
mister bill
Member
connecticut
hi new here have brake issue on my 66 cuda im not a mopar guy but i bought this cuda i love it but i cant stop it someone converted the brakes to disc and i believe they used an improper master cylinder anybody out there can give me help it would be much appreciated thanx in advance fatherbill
Well, "details."
Power or manual and do you have a had pedal and is it sufficiently "off the floor" and just what DOES it do exactly? Have you for example played on maybe, a gravel road to see which end (if either) you can lock up?
Why do you claim "they used an improper master?"
And what parts were used to convert? There are many ways to do conversions, many
Well, "details."
i bought the car with the conversion already done the car never stopped very well however when brakes applied calipers dont releasr okay bad hose or caliper replaced calipers and hoses same issue did some research found proportioning valve not plumbed correctly repaired that now have no front brakes changed proportiong valve no change front not releasing no pedal found replacement master amc or jeep still locks front no pedal found push rod was too long fixed that power bled the system fluid to all wheels have no pedal three pumps it gets some pedallall wheels lock and release have bbp rotors calipers fit 83 volare car uses two bolt mount mounting for master ordered master by casting number came up with amc as a match i dont believe thats the proper one need to know what master i should use im out of ideas
Look you are going to have to improve your typing skills and make some sentences. Calipers "not releasing" could be old stuck rusty pistons, or something holding pressure. Easy to figure that--just crack a like and see if it's under pressure and if the brake releases. Holding pressure can be swollen hoses, but rare, a BIG CAUSE of that is improper master or set-up where the pushrod is too long and holding the piston part way down past the compensation ports
sorry about grammer all of those things have been addressed,new calipers ,new hoses,new proportioning valve,push rod adjusted master cylinder replaced bled cylinder and power bled the system.the master cylinder fits an amc /jeep products is ther another master that would work on this vehicle,have bbp rotors calipers from an 83 volare .i didnt build this i bought it this way
You can make just about any passenger-car master work on that car, that has sufficient fluid moving capacity; they are pretty simple devices.
Whether or not the car stops, is another matter; but the hydraulics will work.
Since Del has your back, Ima going to butt-out. Ol' Del can take care of you.
I’m going to bet the master is fine, probably needs an inline prop valve or a disc/drum distribution block
has inline proportioning valve ,i get pressure to all wheels when i manual bleed, i can feel the shoes move,but i have to pump pedal three times to get a mediocre pedal,like having air in the lines only worse, or way out of adjustment
thats what i think the problem is ,im not moving enough fluid.what master would you recommend using bbp rotors ,calipers from a volare .maual brakes no power
Can you post pics of your master cylinder?
If you're using a smartphone you can click on the upload photos button, then select camera and take a picture. Then click post reply.
Not moving enough fluid is HIGHLY unlikely;
certainly NOT a problem in the calipers, because when correctly installed, the pistons only move a few thousands of an inch. That means even if they are 2.5" in diameter, the amount of fluid needed to travel .004 inch is about .64cc, for the pair!
At the back , in a 7/8" bore, a quarter inch of w/c travel is 2.5cc; so two of them is 5cc, which is .3 cubic inch. (edited)
This mismatch is why you have to plumb the M/C back to front with the rearmost chamber plumbed to the front brakes, see picture below, You will see how the rear piston is able to slide by the discharge port, until the front piston locks up or bottoms out as the case may be; this is the fluid BETWEEN the pistons.
Now before we get started,here are some tips;
1) your front brakes should be plumbed to the rearmost reservoir, which should be larger than the frontmost chamber. Only because the discs do most of the braking, and the pads will wear faster.
2) The discharge port going to the discs should NOT have any residual valve in it. The port going to the rear brakes COULD have a residual valve, but does not have to have it, unless the w/c's are ancient.
3) The Combination valve should NOT be able to pass fluid from one side to the other; that is to say, the front system is completely isolated from the rear. Your MOPAR C-valve has 5 outlets. This device is actually 3 devices in one housing. The top half is just a line-splitter for the front system; fluid goes in on the end and splits to each side of the car. On the rear half, the line enters on the side and exits out the P-valve going to the rear. If the device has an electrical switch on it, then there is a sealed metal rod between the two halves, that only moves when one side has a catastrophic loss of fluid. It's job is to shut off fluid supply to the leaking side. This is important to know, because; if you don't have the switch hooked up to a light, then you have no idea, if it is centered or not. If it is not centered, it will shut off the fluid-supply to one end of the car. So your first job is to center that valve. It is not spring-loaded, but it is a very tight fit in it's bore. Without taking it apart, the only way to move it, is with hydraulic pressure.
If you are getting BOTH caliper action AND brake-shoe action, at high hydraulic pedal-pressure, chances are that the valve is centered at least close enough to work. ....... for now.
4) the Compensating ports MUST be open when the pedal is properly parked. Shine a light into the larger reservoir and gently stroke the pedal looking for the shiny metal to pass by the hole. STOP! put the cover on BEFORE you return the pedal; If you don't, and if there is air in the system, you could get a brake-fluid geyser under the hood, which requires immediate clean up, to prevent the paint from melting. I wrote that ALL in one sentence, so if this happens to you, I don't want to hear about it, lol.
5) At the back, you have to adjust the shoes all the way out to the drums, fairly hard, then back off a few clicks, spin the tires and repeat. This is done to center the shoes and not get a false reading.
6) If you have new shoes back there, in old drums;
The radius of the drums will not match the radius of the shoes. That means, that the shoes will only touch in a small patch in the centers. This will change as the drums drag the shoes around, but they will not have any effective braking action for hundreds and hundreds of applications.
So In this case, for testing purposes, drive the shoes out to the drums hard! Now go check your pedal with the car NOT moving. ALL tests will be with the car not moving.
If you have a lotta travel on the first pump; something is wrong in the front system.
If the pedal is not rock-hard, something is wrong. You could have air in the line, or you could have a mechanical problem.
To find out which it is;
7) Remove the calipers and Clamp the pistons into the bores so they cannot move. Then check the pedal. It better be Hard, and High, cuz with the rear shoes jammed into the drums, NOTHING is supposed to be able to move.
Now hold the pedal down with a good amount of force, then fix the pedal in that position. It better not move! If it gradually sinks, and you cannot find an external leak, then the only possible explanation is that the M/C is bypassing fluid internally, and sending it back into the reservoirs.
With the calipers and the the w/cs locked from moving, NO fluid can move out of the M/C. That means you can check for air in the system real simple. If the pedal is spongy, either; 1) you got air. or 2) your hoses are soft. or 3)you may have a cracked, warped, or belled drum. If you run out of ideas, disassemble the rear brakes and clamp the w/c's into their bores, like the fronts, and retest. While it's apart, fit the shoes into the drums and see how poorly the radius's match; you may want to get new unmachined drums or get your shoes ground to fit your used drums. Either method is acceptable for rear brakes. But if the pedal is hard, then yur done looking for air, and move on.
Now, I know this is extra work, but you can keep chasing your tail, and keep throwing parts at it, and before you know it, the summer will be over. and you may still be none the wiser. So just do what I suggest, please.
8) If it should turn out that the hydraulics are fine, then we are one step closer to the solution.
take a look at this pic.
Suppose your rear shoes are so far out of adjustment, that the front piston is very nearly bottomed in the cylinder.
And suppose that something is also wrong in the front system so that piston #1 has traveled beyond the discharge port. In this case, the front brakes cannot work, and the rear brakes will be doing all the stopping. The pedal, will be very low. And if your rear shoes are not matched to the rear drums, you are in a dangerous situation.
here is a pic of the Mopar Combination valve; on the right is the front brake side. on the left, you can see Proportioning section hanging off,
and how to plumb it; switch up, and P-section to the rear of the car. On the back you can see the metering block attached which your car will not need.
Here is a cutaway of a generic valve, to show you the guts. This is Not a Mopar but you get the idea.
I doubt that. Check that the pushrod is not only letting the master return fully, but that it also has no excessive slack going down. Make certain you get the master bench bled first
Sounds like air in the system. Are the bleeders at the very tops of the calipers? If not they are swapped side for side. No idea how you bled it but it sounds like air. It also could be rear shoe adjustment. If I have or suspect I'd have pedal problems, I bleed the brakes with the rear shoes snugged up until the wheels won't turn. this not only insures the cylinders are seated, but when you apply the pedal, it should be "high and hard" because the cylinders cannot move. Then go back and adjust them. You may have to have some drag until the shoes get seated
When I converted to disks on my 67--which is now torn apart--I used a Linc Versaille disk brake rear axle alnd 73/4 Demon/ Duster front. I ALSO used the factory drum 67 Master, and just ruptured the residual valves. This is a fairly small master. With 4 wheel disks, it has better than 1/2 almost 3/4 pedal from the floor, hard as a rock and stops great. It is a LIE that disks "use more fluid" because the pistons really don't move that far.
ok thats a totally differant master than mine.mine has two bolts only,lines connect on opposite side .can you tell me what that master fits ?
Just throwing this out there.
How tight are the rear shoes adjusted to the drums?
Make sure the parking brake cables aren't binding, keeping the shoes expanded when released.
Yours could be from a kit, or something, but it could work.
I went with a Raybestos MC 36406 (15/16" bore) after not liking a MC36412 with a 1-1/8" bore. The MC36406 works much better. It's easier to push, but does travel a bit lower. I also went with an adjustable push rod.
I looked around and a lot places are out of stock, but Summit substitutes this one.
Dorman M80266 Dorman Brake Master Cylinders | Summit Racing
^^The thing is, I can't imagine even an "offsize" master giving him the fits he's having. Might not provide much braking if too large, and might have excessive pedal travel if too small, but there's only so many that are similar enough to fit.
What made you go with an adjustable push rod?
When I first went from a single pot to the MC36415 I "think" the stock rod was too short. Dang, It was about 9 years ago and I'm not certain. I still have my original and may try it in the 36406, although the adjustable one works fine.
Did you bench bleed the MC?
