Brewers hydraulic clutch install pics
hotrodram
tyrone pa
installed my Brewers hydraulic clutch setup this weekend. What a great setup!
PLEASE let us know how it works on the street .. How much start to finish ... and how much HP you have on this setup
Will keep y'all posted! Never found any pics of this setup which is why I posted. Made 1/8 in plate bung for firewall so cylinder mounts to it. Used heim joint on cylinder rod to run to clutch pedal approximately 2 in below swivel and removed over center spring
Awesome, can you take pics of clutch linkage inside from master cylinder to pedal.
We'll start with how tos from start pics. 68 dart went 383 mag...brewers brand new 4 speed with Wildwood hydraulic conversion. This is bung i made for firewall from back of Wildwood hyd cylinder. Welded this into firewall but also plated rear of firewall for xtra strength
Under dash photos Thurs when I'm home. Will detail under dash steps on what I did.....thanks y'all for the interest! Haven't seen much with pics and info so hope helps with your future installs
Under dash photos. Notice hole drilled in center of cross bracket that used to hold over center spring
Hey, I was wondering how the pedal feels. Is it super easy and engages quickly? Or can you still tell you are pushing the pedal? I like the clutch to engage twords the bottom, some hyd slave cars I have had were up twords the top. Was contimplating it on my notch, mostly for clearance issues. But I really like the heavy pedal. RB with TTI
You deffinatly feel difference between linkage and hydraulic however not super easy like some newer cars. Pressure seems most about mid pedal...engages throwout bearing about 3/4 clutch. I really like the feel of it
are you concerned with that exhaust running directly underneath the cylinder and cooking the fluid? any preventive measures to keep that from happening?
