tomcuda
mopar man for life
What an awesome thread, but I have 2 not on the list, "H6B" & "830", it's for my 1969 barracuda. Thank you!!
H6B H6 = Bucket seats, vinyl, B = Blue
The 830 is likely the scheduled production date August 30th 1968 for the 69 Model Year.
In general, the new model year production date started on Aug 1st.
They are coded 1-9 or A,B,C. followed by the day of that month.
1 = January
2 = February
3 = March
4 = April
5 = May
6 = June
7 = July
8 = August
9 = September
A = October
B = November
C = December
A10 - ?? A01? Light Group - fender turn signals, map, trunk, ign, glove box and ash tray lights
any way to decode a 67 tag?
The A10 code before the SO number is the car's build date, October 10th, 1972
This is likely the same although I do not have the source Fender tag.Does anyone know what a G51 code means? Car is a 1976 Feather Duster.
Check on your radiator support. The last digits should be 00250 according to the fendertag.Total rookie here - been trying to decipher this. Is this even the right fender tag?
Everything make sense!Beg to differ slightly on your explanation of the code shown ahead of the SO number. This is actually known as the Body Frame Date. This is the date on which the unibody shell was built. It can be, but also may not be the date on which the car was driven off the end of the assembly line. All assembly plants in this time period maintained a body bank of painted bare body shells within the plant. Shells were kept there for a variety of reasons.
Colour: The plant tried not to paint successive cars going through the paint shop in different colours. The paint guns needed to be blown out every time a new colour was used, and by running two or more cars of the same colour together it saved them paint.
Options: If a particular car were ordered with a large number of options, the shell may have been held until production control could confirm that everything necessary to build this particular car was in the plant. A lot of white shirt type people were not happy when a number of cars were built and sent directly to the major repair bay to retrofit something that was not available when the car was built.
Complexity: If a particular car required a higher labour content than was considered normal, it made life very difficult for the people on the assembly line to build a number of these cars consecutively. Station wagons and convertibles immediately come to mind as falling within this definition.
Thanks, I appreciate the info.Check on your radiator support. The last digits should be 00250 according to the fendertag.
I would say this belongs on a 65 Barracuda. The 30 under AB is the vode for 273 x 2 bbl. Only year for this code. In 66 the code was 31 instead.Total rookie here - been trying to decipher this. Is this even the right fender tag?
30= 273x2bbl, 5 = automatic, 5 = heater w/defroster, cc = I think light blue, assembled 628 June 28 1965, V76 Valiant V8 wagon,Rookie question: I'm looking at my fender tag and build sheet and I don't see the correlation to the (fabulous) list above. Help? attached is a pic of each... Thanks!
