Tinmannz
I have a broken clip on my 71' Dart's rear window in the lower left corner that needs to be replaced. Just short of pulling the rear window or carving up the gasket to get to the screw, is there another way to get the screw out?
I think that I can use my dremel and cut-off the head, removing the stud thru the trunk. Install a new clip by way of a pop rivet thru the backside to hold the clip and be good to go.
