Mr. Sinister
Devastation Manager
Sorry for inserting info guys….. I am glad nobody ever breaks a single part. I wonder do you even use oil?
You know I read one of your recent posts about how you pulled off the maintenance on your car and motor home all in time to beat the rain, and I thought that was impressive on two parts the fact that it was important enough to do it and get it done no matter what.And that was from sitting all winter. Lol
Now I have to call it a story.
Good Luck.
It's a feel good thing, just like backing off the rockers.If I DONT RUN MY ENGINE FOR A LONG WHILE , FOR SOME REASON , i will just roll the engine over with a big ratchet and 1 1/4'' socket every month..
My race engines never get spun under 50 degrees temp. It sleeps until then
If we had big frozen lakes over on the west Coast and ice drag racing I'd love to do that.Heck we race in temps lower than that.
Did the OP find the root cause of his problem? I'm betting on weak/ permanently compressed springs causing bounce and hammering on the rocker as the cause. Here is a pic of
View attachment 1716150817 1 new, 1 compressed spring. Both from the same batch/ manufacturer built date. The weak/compressed spring caused valve float/bounce leading to hammering on the rocker arm which lead to it's breaking. Excessive/extreme valve lash can have the same results. Backing off rocker arms between long periods of non-use helps longevity. Same for rod bolts in aluminum rods, most quality aluminum rod manufacturers highly recommend it during long periods of non-use.
I run PAC 1355 springs on the intake valves. New intake springs are installed @2.100" and have 450# spring pressure at that installed height. 780# spring rate and 1.130" coil bind. 1200# @ 1.175". They lose roughly 50# after break in. The collapsed spring has 295# at that installed height. The exhaust springs have a slightly different rate as the exhaust valves are lighter and don't have as much lift. You're welcome to come over with your own spring tester and compare it to the 2 that I use.
