Broken Speedo cable
Mr.FT
New Jersey
I need a broken speedo cable, I only need the end that goes into the non rally dash Speedo for Dusters, Demons ect. I'm trying to put together a test gig to test a speedo befor I remove the dash to install. Thanks
I think most 1/4" driver kits contain a 1/4 hex X 1/8 square driver tip. That will run the speedo but not verify its MPH accuracy.
Your car can be a test bed. You'll have to back the cable away from your original speedo and attach it to the loose one. Zip tie it to the bottom of the dash and go.
More how to details if you want
