Professor Fate
Push the button, Max...
Distributor Bushing Installer/Reamer | OTC ToolsIt is sized with a special tool, not reamed.
Some are made with an oversize internally for the jobber crowd. Just hammer them in and go, it saves time, but you have no control over the internal size. Chances are they will be made with a looser tolerance internally, to avoid any binding issues, once pressed into the bush bore.I don't think the replacements have to be sized, I've never sized one.
Unfortunately, the action it preforms is not reaming..even though that how it's marketed.
I am amazed after 30 replies that nobody has mentioned the Melonized [ specially treated steel ] gear/shaft available from Hughes Engines for steel roller cams.
Hughes shows it in their online site but when I called they said they didn't have any and no idea of when they might have more.
About .030 clearance between dist shaft bottom and seat in pump shaft. Measured depth from top of block to slot in pump shaft (new pump shaft with iron gear). As near s I can tell the bushing rim is fine- some scratches but oil slots look plenty close to a new one. In other words, no smoking gun on the dist shaft length.
I’m wondering- I believe this engine has 20w50 Brad Penn oil in it. It probably has a high volume oil pump too. Possibly too much load for the bronze gear?
What do you think?
This is how I think this works, but I'm no mechanical engineer...About .030 clearance between dist shaft bottom and seat in pump shaft. Measured depth from top of block to slot in pump shaft (new pump shaft with iron gear). As near s I can tell the bushing rim is fine- some scratches but oil slots look plenty close to a new one. In other words, no smoking gun on the dist shaft length.
What do you think?
One of the fellas on here head a engine and B engine race parts for sale in the for sale Section today one of the items he has is one of the old Melling Bronze gear shaftsYes I have read about the burnishing tool and that’s what I will use. I have a new bushing, new bronze gear and am awaiting a new shaft. I plan to check the distributor shaft length as I now really suspect it is too long and that may have caused the quick wear.
I see there is at least one person that’s using an iron gear on a billet cam. I was hoping to hear from more folks that have done this, the iron has higher carbon in it and likely would wear out the cam gear. Nice to prove this one way or the other.
Meanwhile if anyone has a melonized gear they want to sell, let me know!
Make sense to me....This is how I think this works, but I'm no mechanical engineer...
Imagine the intermediate shaft and gear shifting it's contact patch with the cam gear up and down by that.030" in relation to each other. Much like setting up a rear end, there are certain ranges of movement that once exceeded begin to accelerate wear of the gears, especially one made of much softer material.
In a running engine, the intermediate shaft does move up and down within that .030" range as the cam and gear speeds change. Under increasing RPM, the intermediate shaft is forced down onto the bushing face and visa versa. This widens the gear contact pattern which, after a point, accelerates the wear of the gears especially the softer ones.
Limiting that travel by using a 1/2" locking collar would result in the two gears maintaining a much closer gear contact pattern that results in less overall wear on the soft gear. Think of a pinion gear in a rearend moving in and out excessively beyond the normal travel specification. That is no bueno. You can often hear the backlash when driving.
Thanks! Yes I planned to use that tool, good to hear that one works. A little concerned over pulling the bushing, I see some folks making a tool from a carriage bolt. Think I'll see if the local auto parts places have a bushing tool that they loan out. Pondering just using the bushing that's in it, scratches and all as they don't look bad and it doesn't wobble so I don't think it's too worn. I'm a bit worried about dropping parts of the old bushing pulling it out.....
I may have found a melonized gear, just waiting to see if it really is.
Thanks! Not sure about that tap- won't the particles from the tap end up in the engine?
That's just an ignorant attitude. You should run what the camshaft manufacturer SAYS run, not what you think might work. You're setting yourself up for failure otherwise.I’d still like to know what happens using a steel billet cam and a standard gear…….actual experience not just what everyone says
