SRT_DSTRHOLC
is this normal? also had little steam or smoke or oil vapor coming out the valve cover...But i didnt see any white smoke out the exhaust...is this normal? The oil is the yellow color its not brown milky its the normal color i believe. I just want to make sure its not a leak.. The engine temp stayed at 190.. These are new heads and gaskets and I did not re torque the heads after cam break in and the head bolts are used
