I stripped my driver seat (1972) to restore it and found one the springs is broken. The tab that holds the spring to the frame along the back is missing and the spring has a break toward the front where it bends downward to attach to the lower frame.
Long shot, I know but does anyone have a spare seat bottom frame that could be used or that could be scabbed for parts? I need the entire outer spring. Shouldn't matter since bottoms are interchangeable left to right but this is the driver side seat.
Below pic. Missing tab that holds the spring
Broken spring
This spring runs from back to front and down to the bottom of the frame. It's clamped to a flat outer wire but I don't need that part.
If you have a bottom frame that is in good shape, I'd be interested in that too.
Broken spring
