Buckets seat questions 1971 Duster
nsantos1
usa
Hello again I’m working on my 71
Someone replace Bech for buckets seat
I removed the cover so I can restore and put the correct cover
My question are this frames are 71 or 72
I know I remove the foam as a complete piece .
If this are 72 can i put 71 covers on it
70-72 should be the same frame and foam, making the upholstery interchangeable for those years.
Having said that, a call to Legendary Auto upholstery would be my next step to verify.
The frames changed mid 71 but the covers and foams are the same. It would be the plastic backs and the locks that differ. You will need the correct wires to pull the covers into the foam. The wires also differ from 71 to 72
