74dusterman
74dusterman
I pulled the 383 out of my 67 D200 to freshen it up. I am planning on leaving the bottom end stock and putting new bearings and rings in it. The heads are the 516 castings. I plan on swapping the 2bbl intake for a 4bbl, maybe a cast iron intake. I am thinking of going with the xe268H cam from comp cams. I am not looking for 600hp or anything wild. I just want a good reliable motor to cruise around. I am open to any thoughts or suggestions on this setup. The truck has 46000 miles on it but sat for 10 years. I have thought about buying a set of aeroheads from Indy. Is it worth it or stick with the 516 heads? Thanks for the help.
