dartfreak75
Restore it, Dont part it!
Yea I'm running .030 I'm out of my good stuff I'm gonna order some more and some new tips on payday. This stuff im using now is ok for spot welding but is garbage for anything else. I cant run a bead for **** with it. Do you prefer the Vulcan over Lincoln wire? I had been running Lincoln. 035 and it did pretty good for me.Looking good dartfreak75. Not sure what size flux wire your running but if it’s .035 bump down to .030 for sheet metal you will have better results. I understand using what you got, because I do that to. But if you make a run to harbor freight the Vulcan wire is cheap and works pretty well. Don’t forget to grab the gas-less tips as well. Keep it going you will be done in no time.
