Just a question can you ascertain the build date from the last 6 numbers of the VIN?
Thanks
Stu.
Thanks
Stu.
Thanks Jeff that’s what I thought.fender tag or build sheet...
NoJust a question can you ascertain the build date from the last 6 numbers of the VIN?
Thanks
Stu.
So, when you say on the body stamping for 68 and older, is that the number on the radiator support and/or the trunk lip? I'm trying to ascertain the scheduled build date on my 65 Dart GT. Thanks, AlScheduled Build Dates are on the Data Plate, Broadcast Sheet, IBM cards, Door Tag (later cars), Body Stamping (earlier cars 68 and older)
Thanks!
Thanks Alan!Build dates on the data plates are approximate.
If you looked at a bunch of data plates for VIN's near yours you might see a pattern, again approximate.
Alan
I'll have to look at my notes for 65 to see what the template was but yes those numbers.So, when you say on the body stamping for 68 and older, is that the number on the radiator support and/or the trunk lip? I'm trying to ascertain the scheduled build date on my 65 Dart GT. Thanks, Al
Rick
