64 SRT8 Dart
So, I may try and build my own small block oil pan and have a few questions.
What would be a good thickness to use for the sump/body...1/8", 3/16"??
I have a sheet of 1/8" 5052 on hand but can order whatever.
Will be using 1/2" for the rails but they will get machined down somewhere between 3/8 and 1/4" after welding. Already have a guy at work that said he'll write a program for the cutting/machining of the rails for next to free if anything at all.
Need to know if the oil pan in my car...66/early A....is the same as what would be in a later A body as far as sump/pickup location is concerned?
Any help is very much appreciated!!!
