ValiantRacing
360 balancers are larger/thicker because of external balancing....IIRC
I was thinking of just the of external balancing not cast crank, Sorry
I'm not sure of this, but I think I heard that some early 273 2 bbl engines had a different intake bolt angle and the 4bbl intake won't bolt up.
Assuming it's a 2bbl. w/ stock heads.
I plan on rebuilding the 904 and upgrading to a 8 3/4 with 3.91 gears ...any can suggestions? ??not sure if I should go. 30 over or stay stock any input
'68 & '69 had cast cranks, hydo lifters, and single piece rocker shafts. They also never hipo 273 engines those years too.
Several years ago a guy was racing a 68 4 door dart with a 273. It was street driven and was running in the 12's. Do a search for factory ratings on compression and see the difference between the 2bbl and 4bbl engines. If the bores are good, you may want to use the pistons you have.
