HuntedDuckV351
Just got my block back from getting the lifters bores bushed. .040 feed hole in the bushings. Next up is to pick the solid roller lifter.
What shop is doing your bushings?I am having mine bushed also. I went with these lifters.Mechanical Roller Lifters - Small Block Chrysler (273-360) | Borowski Race Engines
I went with the bronze bushings instead of needle bearings.
I couldn’t find any negative information on them or any reason not to buy them.
Their customer service was top notch.
I'm not even sure but my builder is in Lake of the Ozarks area and he is well known for building 340 race engines, I don't question who he uses.What shop is doing your bushings?
I was looking at those lifters. I believe they have the .810 wheel. What size csm are you going to run? Which heads are you going to be running?I am having mine bushed also. I went with these lifters.Mechanical Roller Lifters - Small Block Chrysler (273-360) | Borowski Race Engines
Should.make some good power with the -1s and tunnel ram. I currently am running a roller with .660 lift but looking to up it to .700This is a 416 build with Indy 360-1 heads. I have a Edelbrock tunnel ram with two 660 center squirter carbs.
I’m leaving the cam choice up to the builder but the last one is a custom grind I’ll post the cam card.
This should be more of a cam with this build.
I see it’s not easy to read. I’ll post the specs. This is in a stock stroke 340 with Edelbrock heads, tunnel ram 11.3:1 compression at 5K ft. 400 HP / 400 Tq
Lift Int. .544 Exh .525
Duration @ .020 Int 259 Exh 275
separation 111.0
I agree on the .810 wheel reply.I called them and asked what the wheel size is. I didn't write it down. But I remember it being the same size as my discontinued Crane lifters which Yellow Rose suggested when I asked him his preference.
I'll call them tomorrow as I had them shipped to my builder.
ALOT of shops what do itYou are fortunate to have someone close that is as good as he is!
I wanted to tube a 360 a few years ago but never saw it done and didn’t want to mess it up.
I had mine done at Nyes Racing engines in Muncie, Indiana.....give them a call...was done on a Rottler CNC.How much did it cost? I just had my 340 block checked and it passed everything but the lifter bores are pitted. I need to check what other people are paying...
For you guys that have bushed your lifter bores do you still restrict the oil to the drivers side?
