dartjack
I'm thinking of using 360 heads on a 318 build. Without decking or milling the heads what would be a realistic compression ratio? The original pistons are
0.104 down in the block. Heads are stock size with a valve grind done. Pistons have dish and valve notches. My abilities to measure compression volume are next to nonexistant. My guess would be about 7.5 but from what I've read on here that might be generous. Anyone got any hard numbers?
Keep reading. :evil2:
