C-Body Tierod Adjustment Tubes
GaryS
Ponder, TX
I've misplaced the article that tells which C-body tierod adjustment tubes can be used as a heavy duty upgrade for A-bodies. Does anyone have that info handy?
Don't know.... but if a 69 C Body works, I should have a pair in the shed if ya need 'em....
I believe you need to replace the tie rods with the tubes. Firm feel sells them as a kit of 4 tie rods and 2 adjuster sleeves.
Yep C-body thread diameters are larger but the tapered ball studs are the same as A-body. I really cant see the benefit of the larger parts until I go to a much larger wheel size.
The larger tie rod sleeves give less flex and are a better handling feature, and yes you need to use the larger threaded tie rod ends.
