C-pillar question
jos51700
Green Bearing thread connoisseur
Bel-Ray
My '72 Dart originally had body putty in the roof-quarter seam. The vinyl top eventually rotted and the body putty has become microplastics.
I would prefer to fill it with lead for longevity, like older Mopars, but I'm wondering; does anyone ever make a sheetmetal patch that get fully welded over this joint, so that the filler is just more of a skim coat instead of a massive slug of filler?
I figure the patch would have to be hand-cut for each side, but could be perimeter welded using small welds until its sealed. I'm figuring you'd want weld-through primer first to prevent rust from the inside. Or is this a terrible idea?
Seems like a good idea to me!
If you have a donor car you could cut a section just above or below the joint and use that sheetmetal as a starting point for a patch.
I have seen people use metal as you mentioned, and it worked out just fine.
Don’t know if this will give you another option or not, but I had that same problem.
I wire wheeled the filler out.rough sanded the area and used short strand fiberglass. (by Bondo)
Been on there for 5-6 years and still looks like the day it was done.
I've used stuff called ALL-METAL for the same sections before with good results. It's ground aluminum filler. (IIRC) It was in a silver can with blue, red & black script, but I can't think of the mfg. name.
