Calling all 60-2 Valiant and Lancer owners, info needed
Here's the engine compartment of my '62 V-200 more door daily driver. It has a warmed-up 360.
I like that. I am still trying to decide whether to replace the 170 slant with the 225 I picked up or drop in the 318. I had the oem lant rad recored for the oddball and hate to waste it ($400). sb radiator? Ii gues the SB gave you room for a standard sb radiator?
What exhaust man. did you use or headers?
For exhaust I am using P/N 3614368 (left) and 2863549 (right) manifolds off a '69-'70 Dart with a 340 because I think they are the only manifolds that will fit, and it was easier and cheaper than trying to use headers. I don't think they flow very well, but I'm not sure. What say you about these manifolds, Mopar guys?
The 60-62 thread dropped to page 4...well Ive got a question to revive it. Can someone tell me where the headlight ground wire originally attached to.
The headlight ground wire at the headlight bucket is grounded to one of the screws holding the headlight bucket assembly to the fender. The ring terminal sits on top of the bucket and not between the bucket and fender. Orientation of the ring terminal will need to be played with so the headlight trim piece will sit flush. Ring terminal position is less critical on Lancers because they have more room between the bucket assembly and the finish trim pieces.
Postage to and from OZ is real high now. Not that it is ever cheap.
You also need the fan cover panel, but you can build one that will work.
Hey everyone, I am looking for a detailed picture of the hood emblem. My '62 has the chrome, but I also have a hole where the emblem should be. I am thinking about making a replica emblem with my 3D printer. If you could take pictures of it with a ruler, I would really appreciate it!
