hotrod68
The car will hook hard and as soon as the front end comes up about 3 inches off the ground I can feel the tires trying to break loose and by the looks of the video causing the front to come down instantly and the rear tires to bounce, any help? I've tried the shock settings every way but totally loose, and have tried the bars at so many different load settings I've lost count, I even moved the bump stops down to get more front end travel. The car is my 69 dart doing 1.44 60 foots and went 10.06 @ 132, I'm starting to wonder if I need a wider tire? Its a 9 inch slick now, Any thoughts would be great. I only have 1 weekend left to try to figure this mess out. I cant seem to figure out how to upload the video on here for you guys to watch.
