If you need new springs go with the single leaf spring that is designed to use with the Caltracs, otherwise they work just fine on the Street- never now they are there.
I think that is why there is multiple bolt holes in there, so you can get as close to your needed dimension as possible. Probably not optimum, unless you are lucky.
