straightlinespeed
Sometimes I pretend to be normal
I was having a issue last summer and I decided to pull my intake and replace the intake gaskets just to eliminate any question about them not sealing well. So being that I had the top off the engine I decided to look things over. I was checking out the cam wear and was just wondering if the pic below is normal. I have somewhere between 2-3K miles on the cam. The cam is a XE268H. Sorry tried to get the pic bigger but couldnt
Now as for the intake. Im just using standard bolts with a flat washer for attaching. I noticed that a couple of these were loose when I went to remove them. Loose as in I could turn them out by my fingers without force. Is there a way to keep them tight for good?
The engine is a LA 360 with Magnum heads and magnum air gap intake. Thanks everyone.
