Pulled the original 360 out of my 86 w250 apart yesterday. Had 150k on it. Ran fine but oil pressure was a little low and it was getting tired. Noticed the cam bearings are tottaly shot. Flaking and chipping on all 5. Ironically the engine I rebuilt last year and put in it was an 86 block also. The cam bearings looked just as bad in that one before they were replaced. Did Chrysler have a bad run of bearings in the 80s? Out of all the 60s and 70s engines I've had apart, I've never seen bearings look like this.Also what bearing is a good replacement? I'm seeing a lot of different part numbers. Thanks
