Intake Closing Point (degrees)ABDC @ 0.050 lift plus 15 degrees, can I get this reading from the cam card or do i have to degree the cam to find this out?
Intake closing point degrees ABDC will be on the cam card, as well as the duration at .050.
All specs should be checked with a degree wheel and dial to make sure they match the cam card. Every once in a while a cam isnt right. It's been known to happen. It'll save you a lot of hair checking.
