Rat Patrol
If I have a 318/392 stroker, with heads that peak at 270cfm @ .600, 3600 stall and 3.91 gears -
I understand what duration is and how it effects the performance spread of a cam
I understand the effect of lift.
I am OK with the lift at valve vs head flow equation
What I don't get is this:
I have a Dyno 2003 Sim that tells me two cams - one makes more torque and slightly less peak HP - the other makes more epak HP at 500 rpm higher.
Trouble is:
- one does it between 2800 and 6200
- one does it between 3200 and 6800
One makes Peak HP at 5500, the other at 6000.
My converter will work fine with either - so how do I know which is best to pick?
PS - I don't want a "screamer" engine - its a street strip build but I don't want to leave HP on the table either.
Trouble is:
