Rapid Robert
I will check with em, yeah that 2" exhaust restriction is crazy. not sue if I'd wanna risk 7K
Open motors were already on a 2" pipe as were the crates. The difference for 2024 is the crates get a 2.25" pipe and both get a shorty header. If IMCA will let you, Schoenfeld can put a mopar flange on the same spec header the chevy uses. Your definitely going to want the shorty over the cast iron manifold. They are lighter, cheaper and make more power. If you use your 7 1/4 (I still think that is a bad idea when you are allowed a 9" floater) with 4.11 gears and run your 904 in second gear if you have a 1.45 second gear that will give you a final of 5.96:1. That's still a little tall even with short tires, but a lot closer than 4.11 and with out spending any money.I will check with em, yeah that 2" exhaust restriction is crazy. not sue if I'd wanna risk 7K
9 Inch Grand National Floater Rear End Kit, 31 Spline 5x4.75, 58"good info! Yes I see where they have changed the rules for the exhaust. I will call schoenfeld & see I can get that header with a mopar flange. I'm wondering if I should get the kit instead of the finished header & mock it up & see if it will fit my very tight chassis as is or it needs cutting/trimming as things are so tight in a early A body tho I ain't competent in that area (header fabbing). yes a header with a 2&1/4 outlet will be night & day ahead of a log manifold with a 2" outlet. Actually I have a 9" furd rear (not sure what ratio) & not sure what a floater is, that's been sitting & would need to be checked out/gone thru. the 7&1/4 still has 3.73's in it right now which'd be 5:41 in 2nd. I'm thinking I can mod the valve body so it wont shift into 3rd??? (also not my area). Hey stay in touch. RR
Bolt pattern is the same. The common wall between the center exhaust ports is a little wider and the shape is squarer. It is less effected by the headbolt. Take a look at your heads next to a set of non magnums and you will see the difference.Yes I will call IMCA. I didn't know the EQ port spacing was different.
You can't run a roller cam in IMCA.I talked to IMCA & they informed me that i cannot use a Mopar flange on those headers so I didn't even bother to call Schoenfeld. I called Summit & they informed me that I cannot refund my cam as it has been too long since purchasing, Maybe I can persuade them to let me exchange it expecially if I upgrade to a more expensive item. I'd like to go roller with all of the flat tappet hyd cam failures. OK so I need a different cam, can you give a suggested one or what numbers/specs should I be searching for, I'm a bit confused on this. thank you for your time. RR
First, you have to decide what the safe rpm limit for your motor is. How hard can you spin it with out breaking it?Oh OK no roller cam. what specs should I be after along with the 106 LCA?
