[FOR SALE] Cam degree wheels
4spdragtop
Ontario Parts Unknown
Heres 2 for sale. Mr Gasket is used and written on, $20.
Mopar Performance appears new/unused, $40. $50/pair
Plus ride from Peterborough Ontario
Thanks
Steve
Good evening, I will take the one written on please if still available , and if it for small block
:thankyou:
SB vs BB ? Enlighten me....
The MP one is a classic . I have one as well .
:thankyou:
Yeah the MP is pretty cool, but I got a DC one, so thin out the extras.
I'm not sure if there is a difference BB vs sb?
They are just round wheels marked in single degrees with a single hole in the middle... They can adapt to any engine...
Most engine center crank shaft bolts for the vibration damper are 3/4"-16 thread...
The Mr. Gasket with the 3/4" opening will fit the crankshaft center bolt perfectly...
To use the Mopar Performance style one with the 7/8" opening, I went to the local home improvement store (Menards) and found a bushing with 3/4" id and 7/8" od and some washers to stack with them so I can get the MP hole centered properly and tight on the 3/4" crankshaft/vibration damper bolt and eliminate some error from the excess clearance....
I circled the crankshaft/vibration damper bolts for you to see from a screen shot of the 73 Dodge service manual engine tightening reference pages...
Small Block:
Big Block:
With both the BB and SB having the same diameter bolt, they will work on either one.... Just use a bushing to take up the clearance and keep it properly centered....
A hole is a hole, you eat ugly doughnuts, don't you???? :D :popcorn:
