Moparbaker
I've been offered to buy a high performance cam... The thing is that it says "from -64 & up" but my engine is a -89 roller cam engine, so I reckon it won't work, right?
Only if it is a Magnum block.You'll need oil through pushrods to run a LA cam in a roller block. 65'
If you have to ask, it would be better to just say no, it won't work.I've been offered to buy a high performance cam... The thing is that it says "from -64 & up" but my engine is a -89 roller cam engine, so I reckon it won't work, right?
This risk factor is on the machining of the block, more specifically the lifter bores being straight and round. Not the cam and lifters. The internet craze of cams going flat isn’t what everyone thinks it is and is IMO blown out of proportion. In my 38 years of playing with engines and more camshafts changed out than most people would ever do, I have one and only one cam go south on me. That was my mistake. I rushed it. The lifter bore needed to be addressed.I’m with toolmanMike, also why would you want a flat tappet cam when you have a roller cam motor? Just buy a roller high-po cam? Way Less risk of a run flat cam
If the flat tappet or camshaft doesn’t have a taper ground on it, there is the other failure point.
