I did consider this, And I might still. Just bought a set of ISKY lifters, so I will have to hope I can keep the xsting cam in there.Tim,
I would run the Crane 272 with a set of Rhoades lifters. It will run great!
Product Description
Application: Best torque & economy in passenger cars & trucks. Max
compr., 9.5:1, smooth idle, std. axle ratio, good vacuum,
computer compatible. Std. to 600 CFM Carb.
RPM-Range: 1500-4800
Value Lift Int/Ext: .425/.425
Value Lash Hot Int/Ext: .000/.000
ADV Duration Int/Ext: 256/256
.050 Duration Int/Ext: 202/202
Lobe Center: 112 - See more at: http://iskycams.com/cart/index.php?...th=12_14&products_id=600#sthash.4kvmdOZ1.dpuf
