cam interchange
oldkimmer
Kindersley, Saskatchewan,
..............Can a roller cam and lifters from a 98 360 magnum be put into an 89 LA 318 roller motor or is it even doable? thanks........kim.......
I don't believe so, no. I don't believe there's holes in the cam to feed the rocker assemblies. So you would have to drill them or chuck it in a lathe and grove the #2 and 4 journals and stick restrictors in the block passages (remember it will get 100% oiling to the top end once the cam's groved). There's also no snout for a fuel pump drive, although that can be addressed in a couple ways via adaptors or an electric pump.
