Cam lobe discoloration normal?
71DodgeDemon340
Tennessee
Hey guys, finally got started on my slow coolant leak from my intake, got the intake off, got everything cleaned up for the most part. Still a little oil and coolant i have to get out of the valley, I just had a question about the discoloration on the cam lobes, does it look normal?
also hows the wear look on the rocker arm rollers?
Gonna try to button up the intake tomorrow before the cold weather moves in
Yeah I see a couple of blue lobes. That ain't good.
Hard to tell from the photo if that's bluing on those few lobes or there just stained. 65'
Looks like a lack of good oiling to those 2 lifters. And/Or the use of oil for a modern engine that lacking the proper additives for flat tappets causing heat build up cooking the lobes.
using mobil one 15w-50 full synthetic
supposed to pretty high on the zinc and phosphorous ppm
Engine was built by a reputable engine builder. Break in was done by the engine builder on the dyno
I don’t get it. The amount of money we all spend building these motors and then try to save a few bucks by buying some main stream mass produced oil for modern cars in our vintage junk just kills me. Most of us drive these cars lass than 5000 miles a year, this one oil change a year. What’s a case of Penn Grade cost? Less than 100 bucks for 2 oil changes plus some to top off.
Penn Grade or Gibbs Driven. Which both can be gotten from Summit or chity Amazon. Amzoil is also good.
The mobil one 15w-50 is listed for racing and flat tappet applications, its what the engine builder recommended. Actually they recommended 20w-50 but a few years after i had the engine built mobil one changed to 15w-50. Maybe they altered the zinc levels?
Lobes don't look to have excessive wear, a few do appear to have gotten less oil flow. JMO 65'
What would you guys recommend?
The mobil one 15w-50 shows 1200 ppm phosphorous and 1300 ppm zinc. Also list the 15w-50 for flat tappet applications
should i be worried about it?
I use Lucas Hot Rod and Classic oil in mine. 10w30. It has 2400 PPM of ZDDP. I'm not sure your cam is really "hurt" yet, but it's on the way.
I know it cant be “undone” but would i see any issues later on? Eventually start wearing the lobes? Im going to contact the engine builder tomorrow and see what he says.
I don't know. I would step up to an oil with higher ZDDP and cross my fingers. It might be ok. Just no way to know.
So is it most likely a oil additive issue? I mean i cant make them receive any more oil. But i deff can change the zinc and phosphorous levels
